New Member Need Lift Advice For 93
Oh. And if you ever wanna go drop bracket, I will be selling my 5.5 super lift here shortly
thank you 4x4 junkie for noticing that those springs are SOFTER lol i should have said those are the springs that were used in the early full size broncos, Ive found a few now that have used them in rangers and b2s, i already have 3 degree camber caster adjustable bushings and im ok with modifying the spring buckets, so what your saying is you don't think they will compress enough meaning they will give too much lift? so could i try them and measure height change and then cut some of the coils out until im down to the lift i want? (which is maximum lift without drop brackets) this way i get the small lift that i want and a softer spring rate? im ok with doing all that work if that's what i can get out of it unless there is another factory spring that would do the same thing for me without all the modifying
You can cut the coils shorter no problem, however it will stiffen them slightly, though probably not by enough to matter much (they'll still be softer than most stock coils).
I still think there's much more to gain with a good set of shocks though (almost no one has ever regretted getting a set of Bilstein shocks).
