new guy with questions and maybe some knowledge
If you are trying to load pics into TRS
You can load pics into your "Pictures and Albums" section inside your "User CP". Make sure they aren't too big or they won't load.
So they are in my user cap under attachments how do I move them
Hey every one ....I got a few pics up finally I'm having to cut them up so bad to get them to upload that they kinda suck so I'll have to get some more so when I cut them down to fit you actually see a truck
I should have the truck out of the garage next week so I can take some so hope everyone has a good weekend
Not sure what program you are using to resize your images. But instead of "cropping" the image, which actually just cuts the edges off, try to find a menu option for "resize". That will change the size of the overall image so you don't have to cut anything off. I normally adjust it so the long side of my image is around 1028px and keep the aspect ratio locked so that the short side of the image automatically changes by the same percentage. When you go to save the image at a new size, there should be an option for choosing the file format (jpg, bmp, png, etc) and the file quality/file size. I usually play with that setting to get my file size down between 800kb - 1mb in a jpg format.
This message composed solely of recycled electrons. Go green!
I'm not very techy ..I don't own a computer I'm doing all of this on my smartphone it's. (Samsung note 8) which I've only had for a month or two ...but I will figure it out even if I have to ask one of the grandkids to show me how ... thanks for the advice ...I'll work on it
I'm using a Samsung also and I don't see an easy way to resize images using the photo editor provided. So, I downloaded 2 other apps to try out. Both worked, but one is very easy to use. Try " images easy resizer" it's free in the play store. Very simple to figure out. It saved the smaller copy of the image in a new album called resized images.
yeah.....cool thread revival:icon_thumby:
my grand daughter is better with my brain phone then i am. i cant even put pics on the web with it :icon_rofl: so your doing better then i am...:D
Rite on thank for the pointing into the route direction I'm going to down load it ...now see if I can figure it out ....I'll post a picture of one of my projects to see if I can make it work
Ok so the (image easy resize) works great and was super easy to figure out that's awesome .... ......i'll be uploading pictures now thank you for the help
good-looking project. That should keep you busy for a few hours.:icon_thumby:
You're welcome. It's what we do. Everybody helps everybody.
Got a hood of a lightning with some broken corners ....
See if my buddy at the body shop can make it happen
Ok so the big truck is my 2002 f150 super crew I've extended the frame to put a 8 ft bed on it dana70 rear dana60 front 37in military tires 12v cummins built a518 & 205 tcase leather Lincoln navigator interior buckets and console front and rear its just waiting for me to take it all off the frame to brace clean paint the frame and suspension ......then reassemble ......then paint the truck it's going ford tuxedo black
The white (dove gray) foxbody is my race car 1989 coupe 408w 710 lift solid rollor 14.5 compression e85 stick car with 456 gears 2890 lbs without me it's still on a diet though
The multi color foxbody is a 1979 coupe soon to have t tops it already had all the interior from a 87-89 swapped and bumpers from a 85-86 when I got it now I've installed a 5.4l dohc from a navigator getting super charger from gt500 it has a full manual 4r70w with 373 gears
Just a little information on the pictures I uploaded .....but not to much to bore everyone
