neutral towing kit
So is there a kit to convert the transfer case, which is shift on the fly with no choice for neutral (2hi, 4hi, 4low). Or would I need to go with some thing like the remco tranny kit and manual locking hubs? It would be great if I could get the hubs and replace a switch with a little work. Thanks for the input.
Hi threecigarman
Got some good info for you. I talked to Remcotowing.com and they make
a driveline decoulpler for the ranger 4x4. this allows you to disengage
the drive shaft, and tow flat. you don't need to put manual hubs on.
you have to put your switch in 2hi, your auto tranny in park, and turn your
key on one click to disengage the steering lock, and tow.
Jim
Sounds like allot of work/$$$ vs getting under the truck and removing 4 bolts...
Good point but when you are old like me you need all the help you
can get.
