Needin alittle help with my b2
BornRebel
ok so here's whats going on. i have a 89' B2 4x4 that im changing into a 2x4 with a 351 windsor. im almost to the point where im going to swap out the rear end for a bigger one. and im wondering if a explorer 8.8 rear end will bolt straight in or if i will have to fabricate new spring mounts and shock mounts. im also wondering what the rear end code is for an 8.8 with 3.73 gear already in it a buddy of mine told there was somewhere on here that had a list of them but i cant find them. But thanks for the help.
Yes, you will need to weld on new mounts/perches
http://www.therangerstation.com/tech_library/Axles.html
ok thank you i figuered i would bt i thought id make sure
