Need your spring code from door sticker 2.3, extended cab, manual transmission 2wd
ti-force
I'm currently swapping a 2.3 duratec with manual transmission into my 00' supercab (extended cab) Ranger with 3.0, 2wd auto transmission. I'm rounding up parts that I'll need to swap and coil springs is something I need to consider, since I'm pretty sure there's a significant weight difference between an all iron 3.0 with auto and an all aluminum 2.3 with manual. So anyhow if anyone could help out that would be great. If you have an 02' ish extended cab with 2.3, mt, 2wd just look at the identification sticker in the driver's side door jamb and either post a picture or look under "SPR" and reply here with what yours reads.
Thanks!
I don't think you need to change out the springs.. I know pople who have swapped out motors before and never did a spring swap (unless it was a V8 and they wanted stiffer springs). If need be, wait until the swap is completed and drive it and see what you think you need to do.
