need voltage values (or more)!! Reward $50
Seems to me a wiggle test would be in order.
Idle the vehicle and wiggle harnesses until you hear it stumble or stall.
I'd put the original distributor back in there. I've gotten enough complete crap "rebuilds" from Kragen to assign them to the dump. What kind of operation sells "rebuilt and tested" carburetors with the idle screw driven right through the casting?
Mine starts and wont stay running unless u feather the throttle untill its warm. During that time the cel flashes with out the jumper inplace to pull the codes... Check the code and it came up with tps sensor... I am gona change the pcm... my 94 30 was doin the same thing. changed computer and it was fine.
u know i did the wiggle test, and it doesnt seem to stumble or fail unless under a load. its very intermittent.. but it's a code 18 every time.
