- Dec 28, 2009
- Kennett Square, PA
- Manual
Volume
Construction guys can get away with running those little pancake compressors, because they're mostly using nail guns. Unfortunately, the various air wrenches all require fairly large volumes of air at pressure.
I have a little Craftsman tankless compressor I picked up at an auction for a couple bucks that I use all the time with an air stapler and it works great. But it won't run an air wrench at all. For that I use a vertical tank job.
Sorry, I can't give you a recommendation on tank size, but IIRC when I was shopping for mine, all the tools have minimum ratings on them that you match up with the compressor to be sure you have enough pressure and volume.
HTH
-Pete
HTH
-Pete
