need to know
tjoseph
1999 ford range
70s 351 w water pump clockwise. need counter clockwise pump what year can i ask for if any
Yes it's a standard (clockwise) rotation.
302/351 have the same water pump.
Try one for a 96 F-150 5.8 or 5.0 they are the same.
You will also need the timing cover for the reverse rotation pump as well.
Exactly, especially with any 351W pump from a mid 80's to 97 pickup/van. No fuel pump boss though on that timing cover, gotta run an electric pump.
You can run a waterpump for a 79-85 HO 5.0 on your timing cover but the cooling leaves something to be desired as the coolant has to make an awkward turn to enter the coolant port in the transition from the pump to the timing cover. This is why Ford revised the pump and timing cover for the reverse rotation setup on the Stang/pickup/van motors in 1986.
