adsm08
Senior Master Grease Monkey
⭐Supporting Member
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0L
- Tire Size
- 31X10.50X15
The heater core hoses get hot, so hot coolant is definitely pushing through the heater core. The bypass valve doesn't actually have a vacuum line hooked up to it right now, so I don't see why it would do anything in this situation. If i've ready correctly then it only activates when I turn on Max A/C. Still, I should look into getting the vacuum lines fixed and will do that. Thank you.
The heater core hoses are definitely getting hot, so I believe everything is fine with that. I may have installed the thermostat incorrectly and will be taking a look into that. I've purchased a new thermostat and gasket from the Ford Dealership today, so I might take that on this week at some point. I appreciate the advice and will follow up
I've gone ahead and done that tonight. It's supposed to be raining and snowing tonight, so i'm gonna see if that makes a difference tomorrow. Thank you for the advice.
So unclogging the heatercore the first time was after I did everything else. The blend door actuator, thermostat, and other items had already been replaced with no luck but with improvements. I definitely think the heater core needs replaced, I just don't have a weekend to do that myself right now and can't afford to pay someone to do it for me. There is hot coolant running through the heatercore though, as the hoses get hot after running for x amount of time. I did replace the radiator cap, and have "burped" the system properly as I haven't been able to add any coolant since the installations. I think i'm going to install this new thermostat and gasket from the ford dealership, and ensure i've seated it correctly before going towards anything else. I really appreciate the comment.
Thank you for the advice, I appreciate it.
I've just blocked the radiator tonight so i'm going to see if that makes any difference tomorrow. I appreciate the advice.
The cooling system definitely was just water before. After doing a few coolant flushes and running clean coolant, it's still bright green. The first time I unclogged the heater core I got about 10 gallons of gunk out of it. The second time (this year) I did it I only got one gallon out of it until it was clear. I believe the heater core needs to be replaced, but I do not believe that is my problem at this time.
I do not have a temperature gauge to stick in my radiator, but I will purchase one and find out. Thank you for your advice, I appreciate it.
To test heater core function you can just use your hands. Once the engine is at temp you should be able to grab both heater hoses and if you can't feel the difference it is flowing.
Unless you are like my grandfather who is so desensitized to heat that he can and has put his hand on an active stove burner and not noticed.
