- Apr 22, 2021
- Memphis, TN
- Automatic
Working on an”project” and involves a 1990 2.3
I am after specifics of the crank hub vanes. There are two teeth on the ignition trigger cup which create should create a rising edge signal to trigger the ICM. Can someone advise if the system does trigger on the tooth edge, as a rising edge, and if the sensor goes HiGH or low for an output at time of trigger?
Then the CID cup-
Similarly it has one tooth that mitigates firing on one coil pack and allows the other or vice versa. Can someone advise on which pair of cylinders the tooth is involved with and which the void is involved with?
I am working toward a super non-invasive carb conversion system for the 89-92 models. This would retain the intrusive efi upper intake.
If someone has a ford waveform diagram of the CKP/CID from a tech manual that would be amazing.
Thanks in advance folks.
Then the CID cup-
