Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
distributer needs to be hooked to the venturi vacuum port on the carb.
the manifold vacuum decreases when the throttle is openned,and this is exactly when the advance is needed.the venturi vacuum increases when the throttle is openned,pulling more advance onto the distributer.
Hmmm...interesting...I might try that...but the manifold was recommended to me by someone on here years ago and I've used it since without any problems...but that started on the original carb and when I swapped to this one I figured it would work as well...
Not sure though if I even have a venturi vac line on the 5200...now I will have to look it up and try it...thanks~
the vac nipple that holley recommends is actually a ported vacuum just for distys
Cool...go for it!
