need help
only thing in system to check sides is the o2 sensor one per bank (left side - right side) o2 sensor $ 30- $ 80. and yes check timing.
Lean condition- clean MAF and look for a vacuum leak.
idk how to check timeing on this thing.
ill try that aswell. thanks snake:icon_thumby:
Pull the spout plug, put a timing light on the crank pulley and it should be set at 10 degrees. Timing cover must be in place,
Could be a bad injector that is leaking a ton of fuel.
Have you pulled the plugs to see if any one of the cylinders is showing a rich or lean condition?
i did plugs yesterday and all the passenger side plugs were fouled, the drivers side plugs were burned whiteish brown
timeing is dead on, i cleaned the maf and it was better. its acting like im beaing starved for fuel.. the cats are no longer heating up to beaing cherry red.
The white side is running lean and hot, the other side (fouled ) is burning oil. Sounds like you have more than one problem. Also you cant adjust ignition timing, but you CAN adjust cam timing cant you?
i pulled one plug from each side and there fine:dunno:. no fouling or anything.
its still got no power, the fuel filter was clogged and on backwords. i cleaned the MAF and checked for vacume leaks and were good there. timeing is good. i need a o2 sensor on the right bank, would this cause me to have no power?
well i guess im going to take it in for cat replacement
