need help
doc holley
put 4.0 from '94 exloder in my '88 ranger. will crank but will not run unless i hold a gas soaked rag over intake checked all sensors and they are hooked up cant get to run at my wits end please help
Just go back over the basics for a engine to run, Air, Fuel, Compression, Spark, You know you have spark if it can start, check fuel and air first, then a compression check, so check air filter/ intake and check the fuel lines and pump. :icon_thumby:
also check for vacuum leak somewhere
there is OBVIOUSLY something that you overlooked, mis connected, disconnected or crossconnected.
Asking us to guess what and where?
If I could do that I'd be the star of my own TV show making millions of dollars.
The only way to find it is the same way you always find such a problem,
take the manuals for both vehicles and be methodical.
It could be something as simple as a ground wire left dangling.
But anything I tell you is a guess.
And there are too many possibilities to make anything resembling a reasonable guess.
AD
thanks
thanks for the input folks yeah ive been over everything like a million times but ive still been thinking its something simple i overlooked ill keep looking and get back to yall when i find the problem
