I have a 90 bronco 2 with a 2.9. Heres what I need help with. The truck runs great most of the time but sometimes it will act like it is running out of gas or has a short of some kind. It will finally die and you have to let it sit till it cools off and it will start back and run fine till the next time, which might be a day or a month later. I have dropped the tank and made sure the pump filter was not clogged. I have checked and cleaned the seniors on the uppur intake manafold. I've had the wireing checked by someone that seems to know what he is doing. He downloaded the codes and found no problem. I have replaced the fuel filter, coil, plugs, plug wires. dist. cap, rotor button, pick up in the dist. tfi module, fuel pressure regulator. Any ideas what I should try next. Any ideas would help. Thanks
