need a little help and guidence
beast of steel
alright so i want to put a 5.0 in my ranger ive read the tech libary and its just alot to take in with outactually doing anything physical. i have a 83 ranger with a 2.8 and a c5 tranny it was 4wd but i switched out the front end with the 2wd setup. my motor went and i need to get this figured out as quick as i can i need to get back on the road. id like to go with fuel injection. i have a 91 bronco with a 5.0 can i just swap every thing over. and what will i have to buy any help will be greatly appreciated thanks
im not oppsed to makeing changes i just need to get this done fairly quickly just want to get it running and driving then do the fine tuneing later
help to make this go smooth and quick would be very appreciated
**edit**
mac also mentioned useing an aod in my previous post in the wrong forum .... are the aod computer controlled?
"Quick and easy" and "engine swap" aren't mutually exclusive. If you want quick and easy, replace the 2.8 with one that's running. If you're anywhere near south Louisiana, I have a good running 2.8 to sell.
Pick any build here, and read through it. You'll get all your answers.
