Name that lift
I may be wrong but if you're planning on putting them on your 2wd, they won't fit, unless they are from a 2wd, the crossmembers are different from 2 to 4wd. Again I am uncertain:dunno:
It's the old Skyjacker kit "with heavy duty brackets".
That kit was sold alongside their kit "with economy brackets" (drop plate style) long before the Class II kits came around.
I would get out the grinder and trim that cast bracket down some so it more resembles the one in the pic below, otherwise it may rub against the D35 diff housing. Otherwise it's a good sturdy bracket (the opposite one for the driverside beam however is not, but you already took care of that :icon_thumby: )
Name that lift
The brackets are not going on my 2wd dd. They are going on a Supercab 4x4.
4x4junkie, thanks for the heads up on trimming to clear the d35 housing. I don't do any hardcore wheeling so I think my drivers side beam bracket will hold up.
-plumcrazy
