My truck likes to scare me every 5 or 6 years
MastuhWaffles
11/2014 OTOTM Winner
Texas
I need more sleep.
I know my truck is running on 19 years old so, shes getting a little old but I do maintain it and I dont usually have issues. Though things break and a long time ago my trucks thermostat housing exploded (literally) twice and after replacing that with a quality part I havent had issues since.
Well today I was out an about and saw the temp spike, pulled over and shut it down just as the red warning light was coming on. The thermostat housing wasnt leaking and I was really worried this might have been the headgasket going.
I carry a jug of coolant with my so I let it cool down, filled it up and limped it home. At home I filled the radiator completley with water started it up and sure enough I saw the leak.
Turns out one of the heater hoses had been punctured by a clamp and and was spewing water. So, truck is still fine and will live to see another day with a new oem 20 dollar hose. (gonna change clamps to keep that from happening again as well)
clamps will always ruin the hose or fail clamping allowing the hose to pop off over a long enough timeline. faster in freeze thaw environments or extreme heat.
periodic replacement is a thing. pm.
2 years 5 years 25 years.....sometimes exceeding 30....
the newer the crappier though.
a hose made today wont be around in 70 years.....but i have seen detroit diesel hoses and flathead v8s that were still working.
I need to start looking for the leak on my '97, it's starting to drink coolant, probably half gallon in the last month at this point...
I was scheming for my EFI swap yesterday and noticed I have a heater hose puddling on my intake as well. I couldn't see where it was leaking but unless the intake is cracked it has to be related to the hose.
Luckily I will be replacing the barb anyway.
Is there a better style of clamp for these trucks? Screw clamp? Spring clamp? I know my '08 is coming up on 20 years old, though it hurts to say it! 😅
I personally like a spring clamp with a new hose, screw clamp with a old hose. new hoses are more fragile with a screw clamp & I tend to over tighten. A spring clamp usually doesnt work well with a old hose as some will harden & need more tension than a spring clamp can give. Sometimes it has to be a screw clamp either way if its in a hard to reach spot.
But thats my take on this subject.
Yeah, there’s better clamp options, the problem is that most of them you won’t find for sale in a big box store. I’ve had a problem for years of my F-150 randomly blowing the lower rad hose off. Doesn’t damage the hose or rad, just blows it right off the rad. Even tried squeezing two clamps on and it still blew off. When I say it does it randomly, I mean like once every 2-4 years. Random. The last time around I bought a stainless steel T-bolt clamp with a nylock nut. Had to order it from McMaster.
I had similar on my Ranger for awhile. I replaced the radiator for other reasons after the engine swap and noticed that lip on the lower hose barb didn't really have a barb. VERY smooth. Tho I'm sure the engine flopping like a fish out of water was a significant contributing factor. (Driver side mount was broken off the block.)
Im just going to change the one that punctured the hose to a basic clamp that you can tighten with a flathead or whatever, just so it doesnt puncture it again.
