My Truck died last night in weird way
Hiaasen
Ham Radio Operator
SoCal
I have a 2005 FX4 Level 1 that died on me last night with no warning. Driving on the freeway and it seemed to all of a sudden be severely starved for fuel. Still had plenty of battery/spark and it starts but idles very rough for short periods before dying. Pumping the gas pedal evens out the idle but it won't rev above 2k and still dies after a few seconds. No check engine light. I'm wondering if it could be a sensor of some sort or if the fuel pump has (mostly) given up the ghost. Details of recent work:
120k, bought in Feb and did oil change, air and fuel filter, plugs and wires, new Optima yellow top. Just did my second oil change a few days ago. Wondering if there's a sensor in the 4.0L that might have gotten oil into it that could be a problem
Sounds exactly like mine after I wrecked and tripped the inertia switch. Did you hit a big pothole about that time? Can you hear the fuel pump run when you turn the key to run without trying to start?
First thing I would do is get a fuel pump tester gage on the rail and check my fuel pump pressure. Try revving it up and see if pressure drops. Your pump might be giving up the ghost.
Anything in the past 10 days?
Check for a broken PCV pipe/disconnected PCV valve at the firewall too.
I think the only sensor which can "kill" a running engine is the Crankshaft Position Sensor. Yours restarts so I bet it isn't that.
Check operation of the IAC (Idle Air Control) valve.
Unplugging it while an engine is operating properly will result in stumbling of stalling out because you're closing the valve.
If the engine remains unchanged or increases in rpm, you've a vacuum leak.
Remove it and look at the plunger while unplugging and replugging it. It should move around 3/8".
I had a replacement gasket for it standing by.
People say they clean them. Mine was spotless when I looked at it at 48k.
If bad, replace with only a Motorcraft or Hitachi (OEM).
When was the MAF sensor last cleaned? (just asking)
