My New House & Workshop
I went from two incandescent bulb fixtures to four four foot LED lights that are linked when I rewired my little garage. Huge difference. I have one more I'll place over the welding table at some point.
Welding table and drill press are on my wish list. I plan to find an older drill press off of FB Marketplace. I have no desire for a new one. My dad had one back in the 70s-80s that I swear would drill through anything.
Use the welder, build the table. The one at work is only 3/16 plate. We've done enough BIG jobs on it to warp it slightly, but it still works.
There is a guy on eBay who makes a middle pulley setup for drill presses that didn't come with it - looks like high quality stuff.
I have had five floor stand style drill presses - a beat up Craftsman one from the mid 90's, the "mid level" big one from Harbor Freight (piece of junk), an older Atlas one that didn't have a 3rd pulley, a newer Porter Cable (have this one now) and a much nicer Craftsman which I think is also from the 90's. I have that one too and it's usually my go-to for metal. My suggestion when you are looking is to find one that has a table that will move in 3 ways - swivel on the mounting arm, angle pivot on the arm, and swivel on the post. Many do not swivel on the mounting arm and it's VERY annoying if you're missing that feature. Angle pivot is nice but not totally necessary.
Welding table is a fun topic, just my personal opinion but I think it's way more useful as a place to disassemble a transfer case or something than for actual welding. Oil wipes right off and you can't hurt it by dragging heavy stuff across it. But if you weld on it then you have a filthy table covered in dingle berries that you have to clean off. Welding tables are really nice for assembly line style stuff where you've got a jig or clamps to build the same thing 1000 times... what works way better for me is a bench vise mounted to a post that is welded to an old truck brake drum, and one of the little fold up Harbor Freight welding tables. Just food for thought... I use my big welding table for welding about 1% of the time.
I've looked on FB Marketplace for welding tables and I've kind of came to the opinion that the best deal I'll find is getting a new one from Harbor Freight. Yes, I could make my own which isn't a bad ideal if you've got the material laying around, but I feel like by the time I bought the materials it would be cheaper to buy one. I also have limited space, and I don't have the room for the tables I see people selling. Speaking of space, I've also thought that a drill press with a stand might be a better option because it will take up less space than a table. Now that the electrical is done in the shop, I need to clean it up and figure out where I can put these things.
Space for a welding table was also my issue.
I ended up with a Hobart welding table... folds up flat when not in use. It was on sale when I bought my welder.
TV
My dad has a big vice on a stand alone base for welding things.
If he needs a table he has a roughly 18" square with a plate welded on edge on one side of it he puts in the vice.
Most things we deal with are too big or goofy shaped/size to weld on a proper table (that just accumulates junk anyway) It's also nice it can easily be turned or moved around and doesn't take up much room. Something similar is on my wish list if I ever get something bigger than the shoebox I call a garage. Works great for either the welder, torch, angle grinder or whatever a guy needs.
I got a little cheapo folding one for that same reason - I'd rather grow into a "real" one but my folds up and has wheels for the little bit that I'm doing
A mobile vice is a wonderful thing.
This is perfect. I bet that would work for 99% of what I would need to weld on a table. The rest wouldn't fit on a table to begin with.
And yeah... mobile vise FTW.
You know me, a few thoughts.
When I first built my shop, it was an oversized two car garage, one car deep, plus about six or 8 feet for my various tools. When I was crushed during the tornado, I added another 25 feet on the back, so it was two cars wide, and two cars (big pickups) deep, plus room on both sides and also in the length. From looking at yours, yours is somewhere in the middle on those sizes.
Mine isn’t finished on the inside, just 2 x 4 studs. For my drill press, my radial alarm saw, my scroll saw, etc.: I screwed and glued horizontal two by fours to two of the studs. And then I glued and glued and screwed a cross piece about 15 inches out from the wall. Then I ran a 1x3 at about a 30° angle back to a 2x4 cross piece between the studs on the bottom side. Basically, I made a heavy duty shelf where I can jump on the thing and bend the walls, but the shelf doesn’t fail. Then I put plywood on top of the shelf, and that’s what my drill press, my radio alarm saw, etc. are bolted to.
I put them at the height I wanted, and I still have 90% of the storage space below free and clear. No cabinet to work around.
On one wall, from left to right, I have my drill press, and centrally, I have a 15 inch Makita chopsaw. I’m pretty sure it was made for wood, but I also use the 14 inch metal blades on it to cut all kinds of steel and aluminum. To the right of that, I just stuck a 2 x 4 out from the wall horizontally and put an angle brace below it. The height of the base of the drill press, the surface of the chopsaw, and the wooden brace are all the same, so I can put on a 10 or 12 foot long piece of whatever, and cut it with the chopsaw where I want, or drill it where I want. The brace on the right side is only about 5 inches inside the side of the garage door, which is about 4 feet further. If I have to cut something longer, I can clamp another 2x onto that brace with a C clamp, and I can cut 20 footers by just wiggling my chopsaw a little bit to square the cut. All by myself, and I’m a feeble old man.
I use my radial arm saw mostly for finish carpentry stuff, and I have similar braces sticking out of the wall on either side. They don’t interfere with pulling the cars in an hour or me walking by. I probably have it 40 inches or 45 inches off the ground. When I back in the town cars, the wide sides fit underneath. I have reflective strips on the far back wall to guide me.
I still use a stick 40yr old stick welder. I mounted it about 6 feet in the air the same way, and I use a 1x2 stick with a loop on the end to turn it on and off and to adjust the amperage. It’s not in the way of anything.
For my circular saw, I made a “Murphy bed” table. I put horizontal two by fours in between the studs to accommodate a 4 foot wide piece of plywood. I made a 4 x 8 sheet of plywood into a table top by simply building a 2 x 4 frame underneath it. On the wall side, I screwed it to those two by fours with the door hinges. On the outside side, I made two legs out of one by threes. I can jump up and down on the whole thing, and I’m no small boy It’s probably 35 inches off the floor. When you fold it down, it’s a 4 x 8 work table. When you fold it up, the two legs on the outside end fold up far above your head. I have 9‘8“ to play with, but you could simply trim your table down, so it folds up under your ceiling.
I have outlets in two places on that table wired with Romax to the wall. I left about 3 feet of Romax free, so it simply flexes as I fold the table up and I fold it down. If I had to do over again, I would’ve used a heavy duty extension cord type cable, but it has been there since 98 and hasn’t failed yet
I mounted my table saw in the middle of that 4 x 8 sheet, so the surface of the table saw was the same level as the 4 x 8 sheet. It makes it infinitely easier to handle and cut big things by yourself.
From the center line of the blade, on the long sides of the 4 x 8 sheet, I made 1 inch markings to the end of the table on the outside side, and about 2 feet in on the inside side, and then I use a long straight edge to mark those lines with a sharpie. You can line up things you want to cut without ever pulling a tape measure. And again, it folds out of the way. The foreign is half covered with painted glue, but I can still line up things on the table. After 30 years, I’m probably creeping up on replacing the plywood.
I’m saying all this thinking of your welding table. On that same table, you could lay down a piece of ceramic tile bathroom backing board, and lay a piece of quarter inch plate on top of it, and bang, you have a welding table without burning your house down. You could secure it in place with a few screws or bolts, and remove it anytime you want.
Another thing about that table, I regularly screw things down to the table when I want them to hold steady when I’m doing whatever to them. That doesn’t include the cute little brunette. I have a cheap sheet metal brake that I can mount with four bolts on the edge of the table for little things I want to fabricate. I cut glass on it, and it is my go to workbench for all things. I have granddaddy’s 6” vice mounted further back in the shopping a work bench, but I’m looking for another one to bolt down to the table that I could take on and off occasionally.
You get the idea. Universal fold away table. I’ll try to send a couple pictures, but the whole shed of miracle is so overwhelmed with crap and trash from when I was sick and injured, you’d never see these things.
And, as regards a vice on top of a brake drum, let’s make sure it’s a Ranger brake drum.
Hope it helps.
I patched up the ceiling and painted it only to realize I grabbed the wrong can of ceiling paint. 🤦‍♂️
Other than that, the shop is cleaned up. Eventually I want to get a drill press. I had first thought about getting one and setting it on that black filing cabinet, but now I think I want one standing up along this left wall where I have room to work and room to clean up the shavings.
the shop is looking great!
AJ
See a large vise, that is good. I do not see a bench grinder. I would get one of those also.
I do not think that filing cabinet would have been strong enough for a drill press on top of it. If you are going to buy some large bits that go up to a 1inch for drilling suspension pieces and such, you need something you can put some pressure on. And you are right about the shavings, they are a mess sometimes along with the cutting oil.
Event Coverage
TRS Merch
