My 88 bronco II build
yea i get too you in a pm later. still working on truck
ok cool but if you plan on weeling hard you should do a dana 35 axle swap and a 8.8 for the rear
im picking up a 94 explorer this week for 300 bucks....so yea beat ya to it. will be parting that out as well.
good i just got a 8.8 and dana 35 myself good luck wit the swap post pics
i will if i get to it soon. I just need to get my other things worked out first lift and all.
ok here is the deal guys eveything is up forsale on the gray bronco ii,the rear-end is mine,drive shaft as well,high puressure fuel pump (frame rail pump) is too,window motors are gone as well.
so again the parts that are not forsale are..
rear-end,
window motors,
rail fuel pump,
drive shaft.
Anything other then that is up for grabs and it will prolly be very cheap.If i can move this bronco fast i got 2 more to pick up and part out.
By the way if you cut a hole in the back panel for the fuel pump and put a plate to replace the hole it makes the pump easier from now on.
how much for the wide rims and tires that are the grey one ??
and how far are you from the tn/nc border ??
what are you doing with the wheels off of yoru blue BII in the first pics and the tv's and radio out of the gray one?
lol I need a set of rims and tires still. buddy said he would give me his 33s off his yoda.....still w8ing on that.trying to find a nice set of bullet holes or jeep rims. Umm idk about the tv and crap out of the gray one....I know it works..my son watched nemo on it lmao!
I need a set of bummper lift brackets. does anyone have a set to sell or a site to buy them from?
