Got my seat belts and passenger seat in. I found a website that is supposed to have Ford Interior Paint it is a Mustang site. lmr.com. I will look into it.
Notes for myself
https://lmr.com/products/79-93-Musta...aint-Spray-Dye
Rear Axle Codes / Determine Gear Ratio - Ford Ranger Forum
how to read door jam sticker... - Ford Ranger Forum
Coverlay 12-112-DBL Coverlay Manufacturing Dash Covers | Summit Racing
Cutpile Flooring for your 1983-1995 Ford Ranger Reg Cab 2 & 4WD Cutpile | Car & Truck Interior Carpet (ocautocarpets.com)
Inner & Outer Window Belt Felt Sweep Kit without vent windows 83-88 Ford Ranger | eBay
The last year or so I have had problems with the electrical system in my BII, no big surprise, but frustrating. On cold starts the truck would stumble and hesitate and you could make it go if you floored it and stayed on it, but ran rough, especially we you got over 35-40 mph. After much checking of the basics many times, I found all the problems were ground related. The main battery cable runs down towards the block, but stops at the frame where it was clamped to the frame and then continued on to the bolt on the side of the block. Where the bare ground wire was clamped to the frame, the wire was corroded and about half it's normal size. I replaced the clamp on the frame with a bolt and ran two new ground wires, one directly from the battery to the block and then one from the block to the new bolt on the frame. Two of the problems I was having went away.
The next bad ground was the ground from the computer to the body behind the kick panel on the passenger side. The ground appeared to be good with no corrosion, but with the age of the truck the ground path back to the battery had deteriorated. I ran a temporary jumper from the ground bolt by the computer to the battery and took the truck for a drive and miraculously the rest of the driving problems vanished......except for one. I ran a new 16ga wire back to ground point on the front frame by the battery and started working on the last problem.
If you turned on the fan control to medium or high you could see the lights dim and the truck would stumble under load. I took the dash apart and found there is a large ground wire that leaves the fan controller and disappears towards the fuse block, but could not find where it landed but I'm betting it terminated on the firewall sheet metal. I cut the black wire on the fan control and replaced it with a #10ga wire from the controller to the front frame ground point and replaced the spade connectors with a ground lug and re-terminated all the grounds. This solved the fan problem.
Every ground wire I inspected has had some type of corrosion problem, so I am in the process of replacing all of them, one at a time. The Bronco II hasn't run this good since it was new! If you are having any computer related problems that you can't explain......get grounded and see if it solves the problem!
http://www.therangerstation.com/foru...es/biggrin.gif
data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7
Good luck!
Ford Ranger & Bronco II Electrical Diagrams at The Ranger Station
When the 2.9 Liter engine had been around for awhile, I began noticing a recurring problem, particularly on Rangers and Bronco II units with automatic transmissions. There is an orange ground wire that leads from Powertrain Control Module (PCM) pin 49 to the back of the passenger side cylinder head. It should be clamped between the dipstick tube bracket and the head. The circuit inside the PCM depends very heavily on this ground in order to properly read the Oxygen Sensor Signal, and some technicians would forget to reconnect that ground when reinstalling the transmission. Black smoke problems and odd O2 sensor voltages were common with ground loose or disconnected.
Ford Ranger Door Interchange Guide - The Ranger Station
Ford Ranger Remote Mounted TFI Ignition Module (therangerstation.com)
McCully Racing Motors- We have exactly what your over-heated TFI Module Needs!
TB from a '87 2.9L with a opening of 58mm verses the 53 mm for the '88.
An M5OD-R1(M5R1) from a 1990-1997 4.0l Ranger or Mazda B4000 would be a better choice, matching 4WD or 2WD which ever you have
There is a "Mode/Routine" in ALL fuel injected computers call "Clear Flooded Engine"
Its simple to use it
Key on
Press gas pedal down to the floor and hold it down all the way
Try to start engine
If should not start/fire at all, fuel injectors are shut off
Throttle Cable Mod - The Ranger Station
Explorer Overhead Console Upgrade - The Ranger Station
Compass / Temperature Mirror Install - The Ranger Station
Interior Electronics & Upholstery - The Ranger Station
F7
Ford Ranger Rear Axles (1983-2011) - The Ranger Station
Adding Cruise Control To Your Ford Ranger - The Ranger Station
Radiator Early 90 Explorer Automatic Radiator Upgrade for Truck, use 4.0 Upper Radiator Hose.
Axle Upgrade
from 1983-1989 ranger or bronco 2 will have the dana 28 that you have. that will bolt right up....if you are just looking for the front pumpkin that will what you want to look for.
but if you want the whole front end ..as in axles rotors hubs i beams yada yada. you really want the dana 35 from any late 1990-1997 ranger or 91-94 or first gen exploder. some 90 bronco 2s do have a dana 35.
the dana 35 will bolt right up BUT you will need to make your front drive shaft shorter by 1 inch. and you need a new driver side inner tie rod.
