My 84 ranger with a supercharged 5.0 and full width SAS
Sweet rig! Couple questions about your sas: What steering box pitman arm combo? Stock trac bar mount at the axle or fabbed? What heim did you use at the pitman arm, and is it just drilled and bolted conventionally?
I am using the stock steering box with a heavy duty drop pitman arm (not sure of the make though. Got it in a trade). Pitman arm has been drilled out for a 5/8" bolt. The heim joint is 3/4" on the threaded side and the eye is also 3/4" but I am using a 3/4" to 5/8" high misalignment spacer since most of the travel is done on the pitman arm side.
On the axle side for a trac bar bracket i used ballistics fabrication's offset bracket for that. Lucky me they are right here in Tucson :)
:icon_hornsup: love the truck man do you know if theres a company that builds the brakets fir the track bar? im building a 92 xpolder and doing the dana 44 9 inch swap in it thanks
Much of the brackets I fabbed or modified myself. But I did get the coil buckets and trac bar bracket that goes on the axle at http://www.ballisticfabrication.com/
you guys hit me up when you go wheelin I am starting my sas so hopefully I will be done soon I am up in payson
nice truck, I need to buy another rbv
that things dope man. MOAR WHEELIN PICS
