- Jul 31, 2009
- Sweet Home Or
1978
197
- My credo
- i know something about almost everything but not everything about anything.
trans
the zf5 will fit in the truck you need one from a 460 truck, the 205 will bolt up...as will a high tourque starter which you'll need for that monster engine.. you'll also need a racing clutch or something similar... the crossmember needs to be moved/modified and you'll need to install a hydraulic clutch assembly of some kind...if your inguinuative you could rig up a mechanical system, i found the hydraulic easier...
by the way the V8 ZF is supposed to be rated at 600hp breaking threase hold...
