mustang rims
miami ranger
93 ranger and I just bought a set of 96 mustang rims. The size is 225/55/16 and they will look good. the problem is I cant find the correct lug nuts to fit the mustang rim. I had 1o" wide cragars on before. What kind of lug nut do I need to make the mustang rims fit?
The lug nuts from a mustang bottom out and the rim is not held on tight. The original ranger rim lug nuts do not sit flush??:sad:
mustang rims
go to an auto parts store and you should be able to get ones with the right seating angle and the hole all the way through. i dont see why it would be different from ranger to mustang though. i had ranger rims on a mustang with mustang lugs with no problem ( not sure why i did it but i did.)
Has anyone run into this silly problem I am having wit the lug nuts? Any one running the same rims from a mustang as in my pic in the original post? :icon_confused:
thanks for the suggestions so far guys...........HELP !!!!:bawling:
Please some one post a pic of your mustang rims and the lug nuts you are using. I have 96 gt rims and the nuts are not fitting correctly. I have tried three different kind. I have been looking thru the gallery and no luck yet.
thanks
I put 96ish 17" Mustang rims on my truck and used the lug nuts that came with the truck
