- Feb 3, 2008
- Manual
Hey,
I have a 98 2.5 2WD 5 speed with 202 000kms. Running 10w-40 semi-synth
Here's the situation:
When in high gear [4th and 5th, but sometimes third] whenever I tromp on the gas, or try and accelerate uphill / under load, it makes a decided knocking sound. Now, I know what you're thinking, and it's not the sound that I associate with a fuel / timing problem - I think those sound more like a popping noise anyways. Its a fair bit louder, and sounds more like a vibration ... like something is rattling, but loudly and regularly, and ceases instantly when I back off the gas, even the slightest amount. If pressed, i would describe it as a metallic tak-tak-tak-tak-tak sound [....how many of you just made that sound out loud?]
I have been thinking the knock was bottom end, bearing issues - i tend to think worst case scenarios, and it would make sense as the stress on the engine is most severe under load in the more direct ratios. But lately i've been thinking that it doesn't sound like bearing knock either ... too light a sound [and the truck is still running....]
So im back to the drawing board... motor mounts? transmission? valves [only in high gear?]
I'm kind of stumped, so I'm deferring to you fine gents....
