- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Unless you got some distortion in your camera's lens, I think I see the tires (passengerside in particular) flexed inward a bit like the toe is off.
I have to agree, you got MUCH bigger issues to take care of there first than a measly little bit of positive camber on one side...
Edit:
didn't see this until after I posted...
With your setup you're gonna be right in between where a FA400 and FA600 arm would be, being you have bigger coils in there than your brackets. I'd probably get the FA600 arm just so you have it should you decide to go to 4" or bigger drops (which might be needed anyway if you can't get things straightened out the way it is).
Yes, toe is the FINAL item they should be adjusting.
Edit:
Ea I know the angles are bad, and I'm going to put a drop pitman on there, but do I need a extreme drop pitman with those 2.5" drops brackets? But yea I'm finding another alignment shop anyways. Sometimes the camber doesn't look that badbut other times it looks worse. I think I'm gonna put the drop pitman arm on it(would the regular drop pitman be fine? Its a lot cheaper) then get some 4" skyjacker drop brackets and use some washers (in the 4" hole) and camber bushings to dial it in. I'm getting new tires pretty soon and I waant the front end right to not eat them up.
So when they set the toe first then camber the toe is prolly out?
