- Nov 29, 2016
- Roopville, Ga.
- 2.9 V6
- Manual
- Total Lift
- 4 inch body
- Tire Size
- 265/75 R16
- My credo
- Eagles May soar, but weasels don't get sucked into jet engines!
My son has an 89 bronco 2 with a 2.9. He was pulling some logs out of the woods with it and checked his oil afterwards after doing any hard pulling. (400-600lb logs dragging on ground) There was a line of milky oil on his dip stick. I pulled the oil cap off and there was milky oil substance on the bottom of it.
It wasn’t running very long 10-15 minutes. I got him to park it knowing water in oil isn’t a good mix. Exhaust didn’t smell sweet and engine barely heated up. But there was pressure when I tried to remove radiator.
Sounds like a cracked head correct? Since cooling system was pressurized without it hearing up?
I’m looking for an idea to tell my son. Thank y’all in advance.
