Mercon vs. Mercon V??
Jason_J
Tacoma, WA
Somewhere there is a FSB that says Merc V should be used instead of Dex/Merc. My manual calls for Mercon in the Manual trans, transfer case and power steering pump. Is it safe to assume that Dex/Merc is fine as long as it's not mixed with Merc V?
Thanks,
J
MerconV is synthetic.
It's better in every possible way, for each component you listed.
I use it to quiet noisy Ford Power steering pumps. Almost miraculous, the difference it makes.
I also put it in my old 2000 4wd trans/tcase/ps pump.
I put synthetic gear oil in the differentials (you have to suck it out of the front axle).
Synthetic lubes are simply better, hands down.
Mercon V is not necessarily synthetic, in fact most of the time it's merely a synthetic blend. You can mix the two just fine, nothing bad will happen. You can continue using regular Mercon or use Mercon V, it doesn't really matter.
^^I'm glad you posted that; I assumed that MerconV specified synthetic base.
I stand corrected. It can any of the GroupII or GroupII plus oils.
Ford has specified MerconV for at least the last 8 years of production.
Most of the aftermarket MerconV you find on the shelf will be at least partial synthetic.
Some good reading here: http://www.ford-trucks.com/forums/1...arent&transport=fragment&frame=f23fabaa6b878f
I wouldn't be so fast to assume Mercon V is always better.
There have been several reports of Mercon V causing poor shifting in earlier M5ODs. I suspect it may be too slippery for the M5OD's synchros to function properly.
Personally I would stick with plain Mercon (Dex/Merc nowadays) in the M5OD, and use the Mercon V everywhere else (T-case, power steering).
