- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
On 01/03 I went to the junkyard last and saw an F4 axle.. I considered getting it (solely for the locker and Colorado roads, but decided to at least run the numbers and see if I actually wanted that or something else)... so on the way home I ran exactly 75, set my cruise control and noted the RPMs... took a picture a mile later (when it was safe, long stretch of I 76, no cars around me etc...)
looks like slightly under 75 mph, slightly over 3k rpm.
stock 215/70R14 tires fairly new.
all other aspects pretty much stock.
back when I was doing body and bondo I noted the rear diff leaked so I put a new gasket in it, when I had it open I noted the stamp and quick checked the condition, took a pic so I would have the reference in case I decided I wanted to do something later.
The 3 is so lightly stamped as to be unreadable,but it says 3.45 and then later 11 38 (which is the pinion and ring gear teeth count), and ford oval... so tag matches gears matches door tag.
