Manual Trans Radiator Question
Radiators????
was somebody talking about radiators?
both of my kids, 35 & 38, keep hinting at moving south. I keep telling them how peaceful it is in northern Michigan this time of year. no problem social distancing there either.
Did I mention I’ve been water skiing on Christmas Eve? Long time ago and it was very unusual and still cold, but there’s nothing like Michigan cold. Grab Momma and the kids and come visit. My kids same age, but they’re up in NYC are now.
Btw, not about any commission, I’m way beyond that. I’m a very loyal GA transplant. We need your work ethic, education, skills, Values, etc. You’re welcome anytime, I’ll show you around. Cheap flights too, if the virus hasn’t ruined that too, or come down in your Winnebago, as long as it doesn’t explode...
...A more significant consideration might be the capacity of the radiator. I’m not sure what came in yours, but both of mine had single cores and I’m replacing them both with double cores. They drop right in, and I don’t think there’s even an interference problem with the shroud and with the fan. They’re only about $30 $35 more, which is cheap insurance for a higher mileage truck. Basically you can’t have a radiator that’s too big, it’s the thermostat that controls the temperature, and with an older vehicle you might want more capacity to cool, which is cheap insurance for a higher mileage truck.
Ditto on that. Recently replaced FactoryOE JunkPlasticTanked 1CoreRadiator with AllAluminum 4CoreRadiator in 2001 V6~4.0L~SOHC.
Replaced stock 192f ThermoStat with 183f ThermoStat; six months now, temps never out of 183~185f range, summer heat, winter snow.
Should have done this years ago.
I'm waiting for my current radiator to take a dump before I do what you did @DILLARD000. I've been trying to replace the factory plastic bits with metal as opportunity presents itself and I'm already removing the part. Like the thermostat housing as an example. I REALLY want to replace that stupid plastic transmission pan on the 2019. No one makes one yet for the 10R80 but PML and Blackgate Customs says they have one in the works.
Plastic pan on the tranny? In another few years, the whole damned vehicle will be molded from $10 worth of polypropylene pellets!
Yep. Apparently all the 10R80 transmissions have that pan.
wow, new one for me, I knew theyve used plastic for years on intakes & valve covers, my ‘93 had a composite rear diff cover. But a transmission oil pan? Next they will make engine oil pans out of plastic if not already done. Hopefully aftermarket will step in . Just like the plastic radiator tanks, time and thermal cycling lead to cracks/leaks/failure.
Yep, already done. While I don't agree with using plastic in these applications, this ain't your average plastic. It's fully capable of handling the temps and plenty strong in most situations. Bouncing on a stump isn't one of them though.
Thanks for your insights everybody!
Pretty sure I was dealing with a "one design fits every application" for the radiator/transcooler, but wanted to be certain before shelling out the clams.
I swapped out the radiator yesterday. I was going to plug the transcooler ports with a couple of bolts (5/8 fine thread if anyone wants to know). But the bolts were $5 a go at the local hardware shop, and way too long to boot. Instead I just globbed the ports full of RTV. *shrug* Should keep the dirt and bugs out. The plastic caps that came with the radiator weren't very substantial...
I'd considered an all aluminum radiator, but heck, the OEM plastic lasted 22 years over 230+k miles and never overheated. If it ain't broke...
-C
Eh yeah same here, was irritated when the plastic radiator started leaking after 23 years on my truck.... till it occurred to me, that I had *never* gotten anywhere close to 23 years on a conventional radiator, before needing to replace or have cleaned out. So......
A trans pans shouldn't be under a lot of stress.
It isn't but it's being put under a 4X4 that potentially will go off road and there isn't anything to protect it from bashing against a rock. Not to mention the plastic hardening over time and losing it's ability to flex. Metal might not be a whole lot better but at least steel will bend before it springs a leak and dumps the contents of the pan all over the trail and leaving you looking for a tow buddy to get you out to where a tow truck can get to you.
Then there is the whole heat transfer thing. With a plastic pan, the transmission cooler must now be bigger to compensate for the loss of cooling the metal pan provided in the past.
If that pan is left exposed on a 4x4, that's criminally stupid.
Happily, there are options available to rectify that with the 2019+. There are at least two makers that offer a full skid plate kit. The earlier Rangers, you are stuck with the OEM plates or have to make your own and none them offer transmission pan protection.
