M5OD-R1 hard to shift
SamC777
Forum Member
Ham Radio Operator
Norman
OK - USA
Vehicle
Drive
3.0 V6
‘94 Ranger XLT 4x4, 3.0. The standard trans in my truck has been very hard to shift into 1st and more recently 2nd gear. It seems to be progressing to 3rd. This issue began back in May.
Fluid is full and changed within the last year. I had this transmission rebuilt back in ‘23, replacing the clutch while I was at it, and it had run just fine since. It gets easier at faster speeds and higher gears, but starting from a stop, I often have to shift into other gears before it will shift into 1st. And even then, it’s a real fight!
Is this an issue with the synchro’s? Am I looking at another rebuild here?
Most likely the slave cylinder, was it replaced with the clutch?
FWIW, the tech section has a few articles and there is a plethora of posts on this weakest link in the setup. Might try bleeding it (if you ever opened it from the factory original they are almost impossible to bleed right - try elevating the nose since the cylinder sits with a slight down angle, and then using a vacuum to help pull the bubbles out.) Might search here and feel the pain of others (me too, the Previous Owner replaced the clutch without slave), and check out some youtube videos on the problem.
I did replace it when the clutch was done, but I did bleed it as well, so it might not have been done properly. Sucks that it’s inside the bell housing or I’d just go ahead and swap it out. Though that may be my answer here anyways…
Guessing you have a hydraulic issue. Could be the master or slave. I agree that you should try bleeding it first - could have had an air bubble trapped somewhere for a long time that didn't cause a problem and it finally got knocked loose. Are you losing any fluid out of the reservoir?
Some guy just posted an easy way to bleed the Master Clutch, a video with a way to get a free loaner. I'd give that a try first. Bleeding that Master is rather difficult if there's air in the lower lines.
Fluid level is the same as it was when I replaced the master. The slave is suspect, but at this point I suppose it could still be both :/
The new fluid that you refilled the transmission with was ATF, not gear oil, right?
Did you replace the pilot bearing when you did the transmission work?
I think this is one of the better vids that gets it HALF right.
Yup. Pilot bearing, clutch, flywheel, and the master and slave cylinders.
Yep! Mercon V
In my reading chasing down a similar issue I’ve read that using Mercon V can cause hard shifting as compared to the Original Mercon fluid which is now Dex/Merc ATF I believe.
Also did you get anywhere on your problem?
Nah, it seems to have kinda worked itself out over time. Maybe it just acts like that when it gets cold? I’m really not sure. It’s been shifting smoother for a few months now
