- Jul 24, 2010
- Georgetown Ontario
- Automatic
so i had an oil change done and asked my mechanic to check out the front end and see if everything good. he came back saying my right front wheel bearing needs replacing. so i took it to ford (i have extended warranty) and they said...
"two wheel drive bearings are supposed to have some play. 4wd are solid. its the type of bearing. I could crank the bearing down so theres no play, but you will be replacing a wheel bearing every 6 months."
they both do have some play up and down, im wondering if i should just do them myself, as i can get parts at cost, or are they fine? the play is very minimal, but from the guy pulling on it i can see it move.
