lose the A4LD?
genisis88
my governor just went out in my A4LD for the second time in 2 yrs. there are also metal shavings in the pan. should i just chunk the thing? if so what other trans. would bolt up to my 2.9? anyone got any experience with this? any help would be appreciated.
88 bronco II 4x4
Yes, any trans from a 2.9 or 4.0 will bolt up. There is also a C4 and C5 that will bolt up also. You could also do the 700r4 swap (adapter from Advance Adapters). The possibilities are endless. You could even do a manual trans swap also. Your only limit is your imagination and the size of your pocket book.
anyone seen or heard of a 200-4R swap for the ranger? I like it cause it's smaller and closer ratios.
