Looking to convert my 99 oil pressure DUMMY guage to a variable pressure guage
I support common sense
Forum Member
N/A
TN - USA
Vehicle
Drive
2”
15”
I’ve read the articles on converting your oil pressure guage so that it provides active data, but when it comes down to bypassing the resistor it grinds to a halt. My 99’ cluster w/ tach has no resistor on the board. When I took out the guage and put 12volts to the sensor pins and the power pins, the needle only went half way up the guage. This leads me to believe the guage itself was changed sometime between 99’ and 95’ to have a buoy in resistor or bias. I think it was 98’ it changed. My question is, am I correct in my discovery? If so, can I get a guage from a pre 98’ cluster and use that along with a variable oil pressure sending unit?
Just as a bonus, has anyone added numbers to their guage for an estimated amount of pressure?
Common sense would say to put aftermarket gauges in with real numbers on them. Voltmeter, temperature and oil pressure. Do you support this idea? :)
Huh, you got me there:huh:. Has anyone ever placed one so it is aesthetically pleasing?
I put the trio under the dash where they are easily seen. Ford never had any good gauges with numbers on them. You may be a little shocked at what a real oil pressure gauge will tell you during a hot idle, but remember the general rule is at least 10 psi per 1000 rpm. So on a engine with a lot of miles, you may see 6 psi at 600 rpm hot idle. That seems low, but is considered good enough to keep things going.
Or if it worries you, go back to the original Ford gauge. It will read in the middle till the oil pressure gets below 5 psi.
