Got some more work done today/tonight.
I found a pulley that would work on my pump.
However, I ran into a problem with the way that I mounted the pump. I have a half inch spacer that makes it a very strong mount setup. I figured this would be offset by the extra 1/2" of shaft length that I had.
Well the pulley center is offset by a half inch........
When I install the pulley, it interferes with the bolts and sits too close to the pump. This pic is with the pulley not installed, just held up to the end of the pump shaft.
So I decided to "adjust" the pulley.
And some gusseting I added to my tranny/rad arm crossmember.
Then I decided to take apart the pump I got from the van just to see how easily the pump reservoir comes off.
The answer was "pretty easy".
And then I painted some shit.
