lift for $300!?
Rose2300
ID
I found a guy selling his 6 month old procomp 5 in lift kit on CL for 300. He said I'll have to get the bolts for it cuz he's using the ones it came with. also i dont think he will include the brake line kit that it originally came with.
Q 1: i know I need grade 8 bolts, but how many and how long do they need to be?
Q 2: how do I go about finding the brake line extension kit for cheap?
Any help would be greatly appreciated as I'm sure the item will go fast
with a 2.3l you really dont need a lift that big but, if you insist. do you have beams? just get 2 inch coils and a 2 inch spacer to lift the front and 2-3.5 inch blocks in the rear. and boom about 3.5 inchis of lift all the way around for less than 300.
right now my fron susp. is 3 in lower than the rear so Itll end up being 3.5 in total lift because most of the 5 in front lift will be used to level out the truck. it comes with 3.5 in lift blocks so even after that it will still have a slight 1.5 in rake. What do you suggest for the brakeline extension kit?
if you like rake. i like my front to be higher then my rear so i would just do the front (like i did on my truck). also why is your nose 3 inches lower? usually its only two? for the brake line i would check ebay, it has plenty of cheap parts.
As the front coils wear the front end sags.
And since the front end is sagged, it will be more like a 6" lift in the front (5" over stock plus the inch lost from spring sag)
Make sure it is from a 2wd pickup.
I like a little rake, I don't like my truck looking like it has worms with a load in the back let alone empty.
this is my truck as it sits now
lift for $300!?
this is a picture of the guy's truck when it had the lift
lift for $300!?
this is the lift
lift for $300!?
everything looks straight. you should get some 15inch rims before you put it on your truck though.
ill get him down to 250. i've got a set of 235/75r15's with rims lined up, ive been discussing them here on another thread (Is this a good deal). Does it look like all of the components are there? He has the lift blocks theyre just not pictured.
Yeah heavy fire, I can't afford new tires with the lift so I'm going to buy the lift and run the used 235/75's until I can buy new tires.
Also, Does anyone know If a tire shop like les scwhab or Big-O tires recalibrate my speedometer?
Also, On the procomp lift section of the james oaks enterprise page there is an '89-'96 kit and then a separate '97 kit. Does this matter or will it still fit?
