LED Shop Lights
Can always do all the rough work for the wiring, dig it out lay the conduit, ect. If you are running water to the shop for sure to the wire conduit at the same time, two pipes, one hole.
I have the Costco LED shop lights and they work great for me.
I was looking at those last weekend. 29 bucks per, and 50k hour lifespan. I may replace the 4' flourescents in my garage with two of those. They also had a flat panel light that looked pretty good as well. That might be a good replacement for the Kitchen flourescent fixture...
AJ
I happened across some t5 flourescent light fixtures that are used for hydrponics or aquaponics. They are solidly framed, and ridiculously bright. Maybe its in my head, but the grow light makes me feel as if I'm getting the vitamin and mood benefits of natural sunlight. I dont work under it shirtless, it will tan/burn you! I have an 8 bulb fixture with 2 switches, and usually run half the bulbs, unless I'm doing 2 wheeled surgery. its got 54w 6500k bulbs. They probably suck a lot of electricity, but I don't notice after the pool pump makes its dent.
