This truck is a 98 Ranger with a 3.0L gas only. I bout it cheap not running. The previous owner had replaced the engine but could not get it to run right. Turned out the engine that was swapped had one cracked head along with the IAC valve being stuck closed. After I got everything replaced and back together the truck ran ok but very rich. Come to find out the engine was out of a newer flex fuel model truck and had flex fuel injectors. I picked up a set of remanufactured OEM gas injectors but now it runs lean and has even less power. I know my fuel pressure is good is 60psi KOEO and 65psi running. It maintains 65psi when I rev the engine also. I've tried twice to find a vacuum leak with with brake cleaner with no luck. The truck seeems to run better when it is completely warmed up. When its cold it has hardly any acceleration and after a minute or so wide open throttle trying to get up to speed it just falls on its face. Feels like you turned the igintion off. One other thing I find strange is the engine will immediately die if I unplug the MAF.
I'm starting to wonder if the PCM wasn't swapped from the the truck the engine came from. Ford was no help on figuring out if I have the correct one or not. Any Help would be greatly appreciated!
The codes:
P0171 Lean bank 1
P0174 Lean bank 2
P1151 Lack of HO2S1 switches?
P1131 Lack of HO2S11 switches?
The codes:
P0171 Lean bank 1
P0174 Lean bank 2
