leaf springs look flat!
BOL
chino valley Az
I was looking at my leaf springs today and noticed they looked "flat" no arch in them. Plus there are only 4 leafs involved. I have a 91 4.0 Can't I use explorer leafs?
Yep, Explorer leaves will bolt right in. Depending on their condition, I believe they will lift approximately an inch to two inches.
91-01 explorer 4 door.
Try to find them off a truck that didn't have a receiver hitch installed on it. They will most likely be less bagged out then.
So I found a 91 explorer 4door at my local (new) U pickit place. Leaf springs look the same. Can I put f 150 coils on my truck?
Put an add-a-leaf in it.
no you cant put f150 leafs in there to wide. I just did the explorer leaf spring swap into my truck. the explorer leaf springs have a higher spring rating than the rangers. i gained 3 inches of lift when is swapped in my explorer leaf springs
F150 leafs are a bolt in.... just need to be 2wd (2.5" wide) late 80's-early 90's
4wd are 3" wide.
^^^ Learn something new everyday
