- Jan 6, 2009
- Manual
What size is the leaf spring center bolt that holds the leaves together for a 94 ranger. Mine is missing
I was driving down the road and started noticing that I had to turn the wheel to the right to go straight down the road, i kept having to turn it more and more, finally I pulled over and started looking around the truck, I noticed that the passanger side rear wheel wasn't centered in the wheel well
It was slightly forward, looked at the axle and seen that the small bottom leaf spring had slid back and the axle had slid forward. I was only 150 miles from home so I drove a little farther until I found a garage and the guy let me use some tools and a jack, I got the springs lined back up and put a smaller bolt (only one I could find) down through the spring pack and into the block, and latched vise grips on the bolt to hold it in and bungee cords around the springs and axle to hold the vise grips in place. It worked, I made it home safe. I'm going to a buddy's house that has a lift today to do a one piece driveshaft swap and to fix the leaf springs but don't know what size / length bolt I need. Any help would be greatly appreciated. I called the local ford place and they said the couldn't get a bolt or tell me the size but would sell me a whole leaf spring assembly.
