I think carefull work with properly mixed JB Weld is the ticket. I believe the key way is really for line up. I think if you cleaned it real good with brake cleaner and did a real carefull job of applying it and hand machining the key to fit as it should, I think the two (male and female) tapers would keep every thing together when properly torqued. I mean...where could the JB Weld go if the pully is cinched down and the tapers are mated?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
