Just Plain Stupied
thanks for the encouragement fellas!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mo pics...I got a late start on the driver's side fender installation.....(I quit installing at midnight)........left side running board & rough cut board are first step.....
Just Plain  Stupied
Just Plain  Stupied
15 minutes later.....board is cut to size & beveled to fit under-side of running for lots of extra support....it will be water-proofed before being attached to the running board.......
Just Plain  Stupied
Just Plain  Stupied
High-tech fender alignment tools.......fender is starting to fit......
Just Plain  Stupied
Just Plain  Stupied
It's finally in place and rear of fender is snugged onto front of running board.....I'm workin by moonlite & throw-lite now........
Maybe tomorrow I'll get the right length bolts, finish tightening the fender into place, bolt down the running board, & install rear fender.......maybe.......
ALLLLLLLLL-right.......I got up the nerve (those VA meds are rough) to put the rear fender in place on the rear of the running board & bedside, but I didn't screw it down yet....
Just Plain  Stupied
Just Plain  Stupied
ASSSSSSSSSSSS you & I might have noticed, I made a s-l-i-g-h-t misssssss-calkulation on centering the tires in the wheel wells (man, I hope Capt Jay don't see this!). Seeeeeems like I'm 1.250946 inches off !!!!!!!!!
(Remind me not to take the meds while I'm using the calculator)
Seeins how it's a MINOR problem, I'll just move the cab/cap rearward....or was that forward.....anyway.....I'll remove the 10 bolts that hold everything in place and s-l-i-d-e the cab/cap rearward 1.250946 inches.....redrill the 10 chassis holes...and BAMMMM.....it's done....just as soon as I remove the 6 bolts from the bed.....slide it away from the cab .75003 inches.....then BAMMMMMMMMM.....it's really done......(
I gotta say it one more time....there's less than an inch difference between the '89 Ranger & '36 "Ranger" over-all body lengths)
Anybody think the tail-end of the rear fender looks O.K. at that height......or should I raise the tail end an inch or so???????????
Personally I think it would look better up an inch. There's something so sexy about a truck with a muscle car slant
keep it level.
thanks guys...............1 + 0 = 1 ....... 1 div. by 2 = .5 .........O.K. ........ up 1/2 "
EDIT: I studied the fender again this afternoon.......and guess what?.........the inner wall of the fender is formed to fit the bed-side........if I move it up 1/2 ", the fit will be just as the factory designed it to fit in 1936!!!!!!!!!!!!
Between the both of you.........you got it!
Now I need to fab a spring-hangar access-panel to fit below the bed--in front of the rear fender...
