Jeep Wrangler (1990 to 2006) Winch/Tube Bumpers on a 1995 Ranger
Mike Tech
15+ Year Member
I want to know if YJ/TJ (1990/2006) Wrangler Bumpers
will Bolt on to a Ranger.. Im askin Cause I Like the Tube
Bumpers, Plus Body has a Tube Front with Winch, n I just
wanted to know if it would Bolt on to my 95..
If not a Direct Bolt on What Would need to be Changed???
Thank You,
Mike Tech
it would prolly be better to figure out how wide the frame and body is on a YJ/TJ and ranger instead cause than you could just fab up some of your own mounts to hook em up with. Cause i doubt its a direct bolt on. but i don't know for sure
X2
I believe the width will line up but the mounts will have to be fabbed...
i dunno if the cherokee is the right width exactly, but it is within inches if it isn't cause the dana 30 is what like 1 1/2 total narrower or wider(don't remember right now) than the dana 35. But i'd go with an xj before i went with a tj for bumper stuff. OR you can build your own :D
