Jeep Wheels
badbronc92
Colorad Springs, CO
I'm looking at buying a set of 15x8's from a guy who used them on his 98 Wrangler. The bolt pattern is the same (5x4.5- 114.3) but I'm just wondering about the center hole width. It looks to be about as wide as it can be to fit inside its 5x4.5 bolts so I'm assuming it would work but that's just an assumption. Has anybody run wrangler wheels and know the hub holes will work or should I just take my wheel off, measure it, and have him measure his? Yes I'm taking the lazy way first. Thanks all.
Fyi>>>
Same bolt pattern YES, but the hub hole is too small for the front of a 2WD, but dependin on the style of Wrangler wheels you are referrin to, the type like I have can be machined out by a machine shop to be able to use the push through type aftermarket centers.
Look at the pics in my sig and you will see mine................
I blew two tires out in the woods one day and had to use my spare as well as the spare from my buddys XJ. It was a factory steel wheel though. It fit fine (temporarily). The center hole was actually bigger than mine, the wheel was way in though due to more backspacing
