Intermittent longer than normal starts:
Rum Runner
Forum Member
Pelham
AL - USA
Vehicle
Drive
2WD
(1999 Ford Ranger 4.0L V-6 2WD 177,000 miles)
Need some help from the ones in the know. The above truck was running ok a few months ago. I changed the oil & filter and went ahead and had the fuel filter changed. To my knowledge the fuel filter has never been changed. After the new fuel filter was installed I started getting "intermittent longer than normal starts". Recently it has become more regular. The truck is not a regular driver and may go a few days without being started. I keep the fuel tank full and it never gets below 1/2 tank. Could it be old gasoline? A weakened battery? Any and all comments are welcomed.
Truck history:
New IAC valve 115k miles
New crank sensor 145k miles
New Bosch fuel pump 150k miles.
Non-ethanol fuel used since 100k miles.
I'm not the original owner.
I know my truck starts way better when the battery is topped up. The battery tender was money well spent.
Do you have a fuel pressure gage?
How you tried cycling the key a couple times to ensure the fuel system is fully primed?
I just bought a battery tender a week ago. I need to learn how to use it. I do have a fuel pressure gauge. I was hoping I would not have to go there, fearing a fuel pump failure. I guess you attach the gauge and just turn the key to on to check for pressure? If the truck does well with cycling the key twice, does that mean a check valve is bad? Is there any chance air gets into a new fuel filter and causes problems that last? Thanks for the reply.
There are fuel pressure specs for both key on ignition off and while running. You can Google those to see what they should be. Any air in the fuel filter would just get forced out by the pump the first time you start the truck in my mind.
Check fuel pressure but don't get hung up if the pressure bleeds off after a couple hours. Mine does that and I was convinced I had a fuel pump/pressure issue and replaced my pump for no reason. My issue ended up being head gaskets lol. I even tried to diagnose it correctly but still ended up firing the parts cannon at it🤣
Ouch! Replacing a fuel pump to no avail. But, thanks for that comment. It takes my pinpoint focus off of just the fuel system. I have had similar symptoms from a failing crank sensor on the same truck. Also, I am smelling burned oil from time to time after driving the truck any distance. I will pull the truck into the garage and eyeball everything. If not for websites like this one, I would not own Ford Rangers that are 27 & 34 years old. They would be in a scrapyard somewhere. Thank you for helping.
