Intermediate shaft trans bearing noise?
You can use gear lube in that but it calls for GL-4 (not GL-5) which is very hard to find and often contains corrosive additives. I had GL-4 90w in mine and it was a real bear to shift in cold weather. Personally, I would try Pennzoil or Valvoline Synchromesh MTF fluid, you can get it easily at O'Reilly and it will work perfectly in that transmission.
Those transmissions are pretty notorious for chewing up input shaft bearings. I believe you can change that bearing without completely disassembling the transmission. Could be the source of your noise or it could be something else.
Thank you Shran for you advice and knowledge. I ended putting Lucas 85-140wt. I live in a warm climate. I will drive the truck tomorrow and see if I notice a difference. Will also talk with the transmission shop to see if thay have the ability to change the input shaft bearing.
-John
What I think to be the shaft bearing noise seems to be quieter using the Lucas 85-140wt oil. May shift slightly harder in the morning but is fine once driven for a while.
