interchangable parts list
Hey Guy's, will explorer front fenders fit a 96 ranger, got a guy telling me they have the same part number?
Steve
Does anyone know if I can take the front & rear windows from a 1992 ranger xlt & put them in my 1994 ranger xlt??
93 was the major redesign, so I doubt it
Front window... no.
Rear window... maybe. (See below)
If the 92 is a regular cab... no.
If it’s a supercab... yes.
All supercab rear windows bolt in. (There are some later years that all the bolts don’t line up, I’ve heard.)
All regular cab rear windows up to the end of ‘92 were gasket mount.
All 93 - 11 regular cab rear windows are bolt in.
Ok..........
I have built 2 gen 3's (93 & 94) and am workin on 2 more (94 & 95), so I will tell what I have found within these builds, but if you need to know other info, I have the ability to check via Ford catalogin at work:
93-97 fenders, hood, front bumper, grill, headlights, marker lights are a direct swap.
93-94 radiator supports are same and 95-97 are same (2 different PN's)
93-97 doors interchange
93 to 08 beds are direct bolt ons and taillights are interchangeable
92-02 Explorer rearends are direct bolt-in if you want 4" of drop in the rear, if don't want the drop, then you have to weld on new leaf spring perches
92-02 Explorer seats will bolt right in after you swap the Ranger tracks to them, the Explorer seats have the holes made into them for the tracks
93-97 cabs are interchangeable, as are 98 up
82-97 steerin boxes are interchangeable to include the MS boxes
82-94 heater boxes interchange, as does 95-97
I'm sure I'll think of more, but that's all I can think of for now!:icon_confused:
1990 consider 2nd gen
Ok..........
93 to 08 beds are all the same the tail lights are even the same?
The bed itself is the same. The tail lights all fit the hole, but are not all the same lens, some were 2 bulb, some were 3 bulb.
Can i put an exhaust from a 98 ranger to a 91? i need a new exhaust and theres more performance ones for 1998+ years compared to the 91 which has 1 and its sketchy
So much misinformation in here it isn't even funny... 98-up bodies (cabs) are NOT a direct bolt on to earlier model frames. Extended cab models are very close other than radiator support mounts. Regular cabs (98-up) aren't even the same length as any earlier model so they are definitely not gonna work...
I think you need more info about the 91. There were several engine options. Otherwise, your question is a bit too vague to answer easily. Please start a new thread in the general section where it belongs. Give more info about exactly what you want to do and try not to muddy the waters with too much irrelevant stuff. Something along the lines of;
Hello. I have a 1985, 2.8l, 5 speed manu, RWD and the engine is dying. Could i swap a 1991, 4.0l in place of the 2.8?
Or something like that.
Thanks and welcome to TRS.
i know its all here i just thought we should have it a list of things like that in the tech libary for example the body mount thing i had no clue the bodys would swap from 83-2010
Yes it will. I put a fiberglass stepwise off An early 2000 or something and it fit perfectly on my 94.
