Inspection Plate In Between Block and Trans
Put the plate on and be done with it!!!!!
Dave
I understand that, but how do I determine if the flywheel and starter need to be replaced at this point
Pull the starter off and spin the drive gear over by hand. If the teeth are chewed but intact, file any sharp burrs off and call it good, then have a friend slowly turn the engine over by hand and look for broken teeth on the flywheel. Same deal as the starter gear, if a few teeth in a row are missing, it should be replaced. If the teeth are beat up but intact, it's fine.
When I started driving my truck ran very quietly and stalled very easily. It was not uncommon for me to try and start the engine while it was still running because I thought it had died. My original starter and flywheel actually looked pretty good when I took them out.
