Inexpensive pen brake and clutch fluid tester - only 12 bucks
Garth Libre
Forum Member
Tennessee
This business of flushing the brakes every two years always bugged me. I probably end up doing it every 4 years and I've never had a problem. I have a theory that opening the cap should only be done when you're low because you're letting moisture in. Now, I see there's a super cheap and easy pen tester that saves the trouble of buying brake fluid getting a friend or relative to pump the brakes, and then having to throw away a good amount of it because "once you open the bottle it goes bad quickly".
Both master cylinders are vented so air can get it as the fluid level changes. In NH with the cold winters, the amount of moisture condensing from normal hot-cold cycles would be higher than you'd experience but you'd still have some. If you're flushing it out every 4 years and the fluid isn't discolored, you're good. The discoloration is an indication of fluid contamination and rust, if your fluid isn't getting dark, OK. I flush out my brake fluid at least every 2 years to keep it clean. I replaced the complete brake system on my Mustang in August of 1990 and have rebuilt the front calipers and replaced the rear wheel cylinders once in 32 years because I keep the fluid clean. Maintenance pays.
I still have the original fluid in my F150 from 1986... I don't think it hurts to flush it, especially with ABS and stuff involved but I never have and it hasn't bit me.
I subscribe to the school of, it will get changed when the brake lines rust out and need to be changed.
I follow the 3 year plan for flushing the brake system with a hand operated vacuum pump kit. I feel it lessens the opportunity for interior corrosion issues, especially with the master cylinder seals getting chewed up from corrosion build up in the cylinder and a abnormally hard stop running the piston seals over the rough spot.
To each there own. There are people who have driven a vehicle for years with minimal issues and no fluid changes in the brake system.
I think I have flushed my brake fluid only once during the nearly 280K miles on my Ranger. I live in SoCal with low humidity most of the time, so moisture absorption into the brake fluid is very minimal. The brake system has never had any problems other than replacing brake pads (normal maintenance).
The fluid in my clutch system has been flushed many times.
Just ordered that same one, will report back, since I have A) brand new UNopened fluid as a "control", B) clean, in-the-bottle Prestone Synthetic opened 13 years ago, but capped tightly, and C) the nasty, dark 13-year-old fluid that might be left in my front calipers... I live in HUMIDITY-CENTRAL, soze I gotta get some real-world data. :geek:
>>> I mean $5.79 $6.20 (incl. tax) DELIVERED... worth it even if it only lasts a year or two... #ChineseRubberDogShyt :oops::sneaky:
WHY do you think that is?... seals breaking down in the slave? Are you talking about your 2002 w/ M5OD trans?
I was talking about my 2002 M50D. The clutch slave has been replaced several times when doing clutch jobs and the master was replaced once. I also had a problem with 5th gear in the transmission at around 250K miles and had the trans was out several times for that. Each time the slave was bled.
Both master cylinders are vented so air can get it as the fluid level changes...
WHERE are those vents? (Always worried about pressure washing the engine bay...)
Thanks in advance.
Thanks in advance.
On my late 80's rangers and f-150, its in the cap itself. There is a bladder that moves with the fluid level that seperated the fluid from the air. The first time I looked at one the bladder had conformed to the bottom and sides of the master because the fluid leaked out. I didn't know there was a bladder, filled up the master, and had a bad time trying to bleed the system for a few days...lol. Until I figured it out...
AL-righty then!... the OP paid $12 for this gadget 3 YEARS AGO, I followed the very same link and paid $6, and you might be able to get it on TEMU for $4...
1) so the "control" is the new fluid, still in the bottle, opened 6 days ago, capped tightly, but riding out in the humidity, under the decklid, it shows 1% water, well inside the GOOD range.
2) the clean, in-the-bottle Prestone Synthetic opened 13 years ago, but capped tightly, (mentioned above) was used up flushing the system, before my gizmo arrived...
3) the NASTY filthy 13-year-old fluid (plus the opened 13 years ago clean flush fluid) shot right to the top, OVER 4% water content... no surprise, it's Florida.
I'm no Subject Matter Expert, but given the price, I'd say grab one, it may save you the time and expense of changing out perfectly good brake fluid, esp. if you live in an arid climate... and of course on the other side, it may prompt a dolt like me to "get after it" even though fluid looks clear and brakes work fine.
Shows as 6 for me too, plus 7 for shipping to Canada.
