Inexpensive 4/3 ch Amp suggestions
I hate to tell you, but there is no reasonable way you can melt a voice coil by "under powering"...Don't know how you came across this info, but they are blowing smoke up your a$$ and don't know $h!t...
SVT
I do pro audio work for a living, and with pa cabinets if you under drive the speaker with an amp you can melt a voice coil. i have done several repairs for people that buy stuff from thei local guitar center without checking details on what they are buying. usually its the high end of the cabinets that melt, though i have seen it on the lows of a cabinet before. now mind you there are in 1000 watt cabinets and they are being pushed by a 300 watt amp. i have never delt with in car audio but i would assume the concept is the same, after all a speaker is a speaker the concept is the same.
Back in my broke high school days I had very good experience with DHD amps. I had 2 1000w 4ch amps and 2 1000w 2ch amps. For just some 100 dollar cheapo amps I was impressed.
Now i'm running all Orion amps and its no comparison, but neither is the price. LOL
So who knows anything about motorcycle batteries? Here is what i am running for the cooler boombox
(2) Pioneer 6X9s
(2) Blaupunkt 4X6s
(1) JBL 8in subwoofer
Sony CDX-GT540 UI head unit (will run the 4X6s)
Alpine MRP-F240 4ch amp (will run the 6X9s and sub)
XM Radio receiver or iPod
So with this, how many hours can I expect to get out of a motorcycle battery? Should I get 2?
So the cooler is coming along nicely. Found out the motorcycle battery, while small, is not powerfull enough to run the system. Borrowed the battery from the truck and works great. So need to figure out my battery situation
Other issue I am having is i cannot get the amp and head unit to work at the same time.
*I have the amp power connected to the positive terminal, the ground to the negative terminal.
*Connect the headunit power to the positive terminal and the amp comes on As soon as i connect the headunit ground to the neg post the amp turns off. Are they grounding each other out? What else can I ground to? The cooler is plastic. Thoughts?
So I think I am going with a deep cycle marine battery. Advanced Auto has one on sale for $60
So need to figure out my grounding issue. Thoughts or ideas (see issue in previous post) ?
It is done!
Just have to tie down the battery and put on some lawn mower wheels (current wheels useless off road) and it is officially done
(2) Pioneer 6X9s
(2) Blaupunkt 4X6s
JVC head unit (runs the 4X6s)
Alpine MRP-F240 4ch amp (runs the 6X9s and sub)
XM Radio receiver/MP3 player
2 fans (in and out)
Deep cycle battery (used for golf carts, wheelchairs etc and lasted a surprising 8 hrs at a moderate volume)
click to play
